pitman arm/tie rod
Old Jun 3, 2001 | 11:25 PM
thefastest's Avatar
pitman arm/tie rod
Im replacing the Idle arm, center link.
I got a problem I neeed answers to !
1. the tie rod bolt that connects to the center link(on the side near the pitman arm) keeps spinning when I try to put the bolt on?
Old Jun 4, 2001 | 12:52 AM
Z_Ghost's Avatar
1 try to pull down on the tie rod and have some one start the nut.
2 tap it with a rubber or plastic mallet
3 sand the shoulder with 220 sandpaper to rough it up a little bit and then hit it with the hammer( see #2).
The tie rod end has a taper to it and fits snug in the hole, you just need to get it in far enough to stop turning.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
