Installing UMI Adj. Torque Arm, Questions
Old Aug 12, 2010 | 08:15 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am getting ready to install my UMI adj. tunnel mounted torque arm right now and I had a question. Where the front of the torque arm bolts to the mount on the crossmember, should I use the top or bottom hole? What difference would there be depending on which of the two holes I chose?
Old Aug 12, 2010 | 05:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Re: Installing UMI Adj. Torque Arm, Questions
yes there is a difference, but you will ahve to see what works best. Use the top hole, see what happens, then try the lower hole. Dont forget to set the driveline angle when you change settings.
Old Aug 12, 2010 | 06:26 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
What would be the difference between the two holes? What does it change, the instant center point? Also, what affect would each of the holes have whether I chose the lower one or the top one? Thanks for the help.
84z96L31vortec
Aug 20, 2017 12:16 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
