What is this and why is it here?
Old Aug 14, 2010 | 12:30 PM
TimeTraveller's Avatar
Car: 92 TA convertible
Engine: 5.0 TPI
Transmission: 5 speed
Axle/Gears: 3.08 posi
I'm in the process of rebuilding the frond suspension on my '92 'vert, Time Machine. When I took off the lower control arms, I discovered these protrusions. What are they, and why are they there?
TT
Attached Thumbnails What is this and why is it here?-front-susp-teardown-004.jpg
Old Aug 14, 2010 | 12:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: What is this and why is it here?
steering stops, the contact the spindle to keep the wheels from turning too far. Your alsmost looks bent a little
Old Aug 14, 2010 | 02:16 PM
Engine: 5.0 TPI
Thanks! I had no idea. I'll have a look in my shop manual to see if I can find the correct angle...Or is this absolutely necessary to keep?
TT
Old Aug 14, 2010 | 03:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
TT
not going to find a correct angle in a shop manual. I think its supposed to be just a simple 90 degree angle from the a-arm, yours looks bent open some
When the spindle is installer, and turned all the way, the stop will hit the bottom of the spindle on the side with the caliper. so long as it hits, its probably fine.
Old Aug 14, 2010 | 03:59 PM
Twin_Turbo's Avatar
Not 90 deg!
Old Aug 14, 2010 | 04:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i stand corrected
Old Aug 15, 2010 | 06:03 AM
Engine: 5.0 TPI
Thanks, Twin Turbo!
BTW, that's the cleanest chassis I've EVER seen! Nice work!
TT
