I've just purchased a moser 12 bolt and pro-kit eibach springs. Will it be a good idea to install some LCA relocation brackets? And will they still weld on directly to my 12 bolt? Thanx
1992 CAMARO Z28
STOCK
[This message has been edited by BORLAZ06 (edited June 08, 2001).]
1992 CAMARO Z28
STOCK
if the brackets are made to fit a 7.5 10 bolt good chance they won't fit a 12 bolt. the brackets aren't hard to make. look at a few pics or catalogs and set your pinion angle then make the brackets to fit.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
I also have a Moser 12 bolt, and the relocation brackets I got from BMR did not fit. I will probably make my own. You might want to check with Steve Spohn and ask if his will work with that rearend.
Brian
1987 Firebird Formula
Currently undergoing full restoration
Brian
Our brackets work on a Moser, I install them on Moser's here all the time. It's a little snugger fit since their mounting brackets are a tad heavier wall then the OEM rear, but they go on with a little pursuasion.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Steve
