which performance front calipers/rotors should I get?
Old Jun 18, 2001 | 09:23 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am rebuilding my front suspension and compeletely redoing the front brakes, replacing calipers and rotors.
I know the 1LE conversion is short on parts and I was wondering if there was a semi-bolt on replacement from baer or someone else that was reasonable compared to the 1LE.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Planning: hedman 1-5/8 longtubes, NOS 150 plate, world 305 heads, replace the "peanut"! and other susp. mods.
check it out at:
http://www.geocities.com/transam617
Old Jun 19, 2001 | 02:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The closest Baer has to the 1LE setup would be the "Serious Street" kit with 12" x 0.81" rotors for $1155.23, or the "Sport" kit with 12" x 1.1" rotors for $1207.98. Both of these kits use the same PBR 2 piston aluminum calipers as the 1LE.
Old Jun 20, 2001 | 07:08 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Apeiron:
Please tell me that's Canadian dollars your talking about.
Because if it's not they'd be about three grand here.
Old Jun 20, 2001 | 08:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Nope, US dollars.
Old Jun 23, 2001 | 10:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Stainless Steel Brakes also have a 1LE conversion kit for $1,195
NORTz89
May 20, 2020 03:51 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
zayne0
Aug 24, 2015 07:22 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
