Difference between convertible and hardtop chassis?
Old Jun 26, 2001 | 10:37 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I was just wondering why there are some suspension parts made specifically for convertibles. What are the differences in the chasis, besides the obvious? Will some headers work with the hardtop and not the convertible?
Old Jun 26, 2001 | 01:28 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Only difference I could see on my Convertible is the 2 steel beams they ran along the rocker for chassis support. My 3" exhaust ran fine not even close to anything.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jun 27, 2001 | 02:40 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Convertibles have a formed sheet metal reinforcement riveted just behind the lower ground effects (in fact they have to trim the back side of the gfx to fit them in). This is where MOST brands of SFC's mount. Only two brands will work (so far). Alston's are what I have. They are sold on the Internet either directly from Alston or from Internet Racers Supply (listed as their "Terminator" series). http://www.racenet.net/. Unfortunately they have dropped the thirdgen ones from their online catalog. Call them. A local Member recently ordered a set and found out that Alston is doing a production run for Thirdgen's. The other brand that I hear of working is from Kenny Brown. http://www.kennybrown.com/home.html. PS: I plan to make SFC's for convertibles in the future as well (hence my prior reference to "so far"). My newly formed (and soon to open for business) company is called Top-Down Solutions (626)369-0040. Good luck, Lon. 8^)
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
LittleFranks
Aug 20, 2015 03:55 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
