Suspension Uprade??
Old Jul 19, 2001 | 02:59 PM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
Suspension Uprade??
I am looking to upgrade and replace my suspension on my 1985 Iroc. It is completley stock and in bad shape. I definetly need new bushings, shocks, struts and god only know what else.
I would like to know what would be some suggested replacement parts. Or what combinations some of you are using.
I would like to be able to drive the car daily, as well as drag race and autocross on occasion.
Any information would be greatly appreciated.
Thanks,
=Scott=
85 Iroc
96 Impala SS
=Scott=
85 Iroc
96 Impala SS
Old Jul 19, 2001 | 04:54 PM
ATOMonkey's Avatar
Definately bushings, also replace the Lower Control Arms and Track Bar with aftermarket parts. I don't recomend the Edelbrock, because they are kind of pricey for what you get. Be sure to use good shocks and struts like Koni or something. Also do a brake job while your down there and have everyting apart.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 Harwood snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Jul 20, 2001 | 04:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have an 85 IROC. I replaced the front sway with a hollow 36 mm bar (mycbar already had the matching solid 24 rear). I used GM 1LE poly end links and higher durometer bushings. Beefed up the wonderbar with a Global West version. Global West SFCs, Spohn LCAs and panhard. Poly tranny and torque arms mounts. The ride is firm without being harsh.
JamesC
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
