Suspension Hardware?
Old Sep 16, 2010 | 09:54 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I've started pulling the suspension parts out of my Bird and I've noticed that the hardware seems to not want to fully cooperate in coming apart in places (sway bars, LCA's, etc), and has to be cut off (pass side LCA) or breaks. My question is, since I will be purchasing a LOT of new suspension pieces (LCA's, torque arm and track bar, bushings, shocks, springs), how many of these come with new hardware, if any, and if they don't come with hardware, where do I get new hardware? I can probably clean up what's halfway decent with taps/dies and a wire brush, but there are spots where I'm going to need new hardware (pass side LCA HAS to be cut off as the bolts are frozen in the bushing sleeves).
Old Sep 16, 2010 | 10:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Suspension Hardware?
Here are some:
http://www.spohn.net/shop/1982-1992-...Hardware-Kits/
JamesC
Old Sep 16, 2010 | 10:13 AM
Engine: 2.7L V6
Axle/Gears: 4.41
I'm drooling here... So tired of looking at all of the rusty crud under there. I think I'm going to have to rename my project "Rust MUST Die!".
Is it a good idea to put these in coated with anti-seize? If I have to remove some of these parts, I don't want to have to replace bolts again.
Old Sep 16, 2010 | 10:28 AM
JamesC's Avatar
After the nightmare I experienced with my a-arms, I used anti-seize. Chances are, however, that it's unneeded a second time around.
JamesC
Old Sep 16, 2010 | 08:47 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
JamesC
is that a chance your willing to take though?
Old Sep 16, 2010 | 09:05 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The reason I asked about the anti-seize is that I know there are some bolts and nuts you're not supposed to put anything on (wheel lugs, for one). Even though there should still be enough of the stuff left on the threads when the hardware is separated, a tube of anti-seize should last long enough (years) for re-application if needed.
Old Sep 18, 2010 | 07:38 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Use anti-sieze.....
I installed a new panhard bar a while back (Aluminum adjustable version). After some time hammering it with an impact gun, I managed to get the original hardware and the bar out. Reinstalled the bar with original hardware, all was good.
Fast forward some time (Not very long)... I'm forced to part out my car, and I'm removing the panhard as part of that. But the bolt on the drivers side has siezed to the sleeve... Not fun. Learn from my mistake, use anti-sieze
Old Sep 19, 2010 | 03:05 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
being from new england, i know weather's not kinda to my vehicles. if you can use stainless, go that route. i'd also use anti-seize where possible.
Old Sep 19, 2010 | 05:48 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If I can find stainless suspension hardware, you can bet I'm going to use it. Should go nicely with the stainless brake and fuel lines I'm going to put under there. And anti-seize is going everywhere as I have WAY too many bolts that are breaking and freezing up.
Old Apr 22, 2011 | 11:23 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Bringing this back from near-death:
Wondering where to get the U-bolts for the rear sway bar mounts (IIRC, that's what they were used for as we don't have leaf springs). Are these dealer-only? There was a couple of other things, but I need sleep and I forgot ATM...
LT1Formula
Oct 8, 2015 08:34 PM
sjorgens
Oct 1, 2015 07:54 PM
