strange sound when turning hard
Old Aug 11, 2001 | 01:42 AM
84berlinettaV6's Avatar
When I turn my steering wheel all the way to the right or left I can hear bad noises coming from my front end. It happens at very slow speeds. It is kind of a squeaky noise along with a knocking sound as well. The squeak isn't my tires either. Thanks in advance.
Old Aug 11, 2001 | 11:47 AM
jf89rs's Avatar
sounds like the wheel bearings. when was the last time the front end has been checked out?
Old Aug 11, 2001 | 12:52 PM
AntiVTEC's Avatar
Is your steering loose? Do you have any aftermarket suspension items up front? Your sqeaks could be coming from some worn out bushings up front.
Old Aug 11, 2001 | 12:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It could also just be the PS pump bleeding pressure internally, which is normal.
B_Dubya
Aug 26, 2015 05:09 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
red90IROCls1
Aug 25, 2015 06:56 AM
db057
Aug 22, 2015 08:17 PM
TheExaminer
Aug 19, 2015 10:07 PM
