power steering pump shaft DIA for pulley?
Old Sep 23, 2010 | 10:39 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Hey guys need to know what the pump shaft DIA is for the pulley? Im getting a reman fenco power steering pump and I need to get a pulley for it but Im going aftermarket to match my other pullies. Waiting for the pump to come in but i need to purchase the pulley .
IS the stock pump a 5/8" keyed shaft? or is it a 3/4" press fit shaft?
I need to know ASAP so i can purchase the pulley so i can make brackets to mount the pump.
Old Sep 24, 2010 | 12:21 AM
Guest
Guest
Posts: n/a
Re: power steering pump shaft DIA for pulley?
Mine was a Singnaw pump with a press fit shaft. I believe all serpentines are press fit, not keyed.
Old Sep 24, 2010 | 10:30 AM
Car: 87 TA clone
ok. well my 87 stock setup wasnt a serpentine setup which is why im asking
Old Sep 24, 2010 | 01:57 PM
Guest
Guest
Posts: n/a
The prior pumps were not keyed either.
I'd like to point out the holes are in different places from non-serp to serp though. Just in case.
Old Sep 26, 2010 | 05:51 PM
Car: 87 TA clone
i got the pump and its def NOT a keyed shaft. Looks to be a 3/4" or 7/8" shaft DIA too. I thought the pumps only came with 5/8" keyed shaft and 3/4" press fit shafts? the ruler i was using had a really loose end so it could have been off but it was def a 3/4" or a 7/8" shaft.
couple of questions tho if you guys dont mind. How do i plug the threaded holes in the back of the pump? I cant remember if the stock pump had bolts in these threaded holes and i believe it did. In that case... does anyone know the thread size? same goes for the threaded holes in the front of the pump? Also The shaft seems to be threaded... is there a bolt that goes down and presses on the pulley? or is that for the install tool?
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
toronto formula
Nov 10, 2015 06:17 AM
backtothe80s
Sep 5, 2015 12:39 AM
