Strut Tower Bushings
Old Aug 16, 2001 | 05:29 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
I have been experiencing front end problems with my 88 Camaro ever since I started to restore it. The car seems to eat up the front tires. I changed the struts and ball joints and all the steering components. The tires are still getting chopped up. Today on the highway the car had a constant vibration and the steering felt sloppy. I work at a garage, so when I got back I jacked up the front end to see what might be the problem (again). It took about ten minutes to figure it out. My strut bushings on top of the strut tower were both torn and broken. They never have been changed. I advise everybody out there to have those bushings checked out. All I did was put a floor jack under the cross member in the front to lift just the front wheels off the ground. Open the hood and take the caps off of the strut bushings (if they are still there), look in there and see if they are in one piece. Mine are not, they are wasted. $85 for new Gabriels with lifetime warranty.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 350CI, 2bolt,.030 over, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
