14' wheels when I should have 16's
Old Aug 19, 2001 | 05:23 PM
Joe91Z28's Avatar
My car is a 91Z28 with 14" rally wheels on it (of course it should have 16"s). Is there an offset on these wheels? Can I rotate them without troubles?
[This message has been edited by Joe91Z28 (edited August 21, 2001).]
Old Aug 20, 2001 | 02:56 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Yes they are offset. all 82-92 thirdgens have a -16mm offset in the back. You can have a tire shop rotate the tires front to back, but not the wheels.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Aug 20, 2001 | 01:29 PM
Tas's Avatar
Tas
14' = 14 feet
14" = 14 inches
took me a while to get a hang of it too
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Aug 20, 2001 | 03:12 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
<font face="Verdana, Arial" size="2">Originally posted by Ward:
</font>
I'm pretty sure this is not accurate. I know the IROCs and (maybe?) formulas (maybe all 16" wheels) had different offsets front-to-back. I am pretty sure that any steel wheel found on a thirdgen or the 15x7 Z28 or TransAm wheels DID NOT have a different offset. The ones that did have different offsets have the words FRONT and REAR clearly cast into them.
Somebody please confirm some of this...little help?
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old Aug 20, 2001 | 03:45 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I measured my 15's and they were the same. Only the 16's were offset and it says on the back of wheels REAR and FRONT for the 16 inchers not the smaller wheels.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
&lt;p&gt;&lt;img border="0" src="http://www.bharris.org/images/smcamconv.jpg" width="200" height="73"&gt;&lt;/p&gt;
Old Aug 20, 2001 | 04:06 PM
82camaro's Avatar
Car: 82 camaro SC
What he said, only the 16's can't rotate back to front.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 20, 2001 | 06:30 PM
Joe91Z28's Avatar
Yea, I caught the 14' instead of 14" mistake myself, I didn't hit the shift key good enough! Anyway, I checked the wheels for a FRONT or BACK stamped on the wheel and couldn't find either, but there is a difference in the backspacing. The front wheel backspacing (including tire bulge) is about 4.5 inches and the back is 5 inches. Guess I'll leave them where they are now. I even called a dealer and they didn't know...thanks for the feedback.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
