spohn needs a V6 K-member
Old Sep 30, 2010 | 10:40 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
owkay,
yesterday I asked spohn if they got somekind of K-member for the 60 degree V6. because at this moment we are left in the cold by all the suspension and chassis tuners.
anyway this is what they told, me
What we have now I'm sure wiould not work. We've had a few requests for the 3.1 V6 application but we need someone to send us their stock k-member and all the motor mount parts so we can mock up and jig a 3.1L version.
so now my question is, is there anyone with a V6 K-member that they can send to spohn ?
reason im not sending mine is because its in use, and sending it overseas would be a wee little bit to much if you can find those things there in your backyard.
Old Sep 30, 2010 | 09:08 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: spohn needs a V6 K-member
A guy on our v6 boards swapped in a 3x00 and got a tubular K member, Idk offhand what he did to make it work though, but if its not viable to use the one they sell for the rwd engine he might have and could send in-heres a question, does whoever parts with their K-member and tests the new one get it free??
Old Sep 30, 2010 | 09:35 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
the V6 K member is the same as the V8 one, it's just the mounting hole locations that changed. All third gen K members have the holes for the V6 mounts. Someone just needs to send them a pair of bottom mounts and a picture of how they fit.
I have a Spohn K member with the SBC mounting pads in my V6 car, i had to make my own motor mounts but that was fairly easy. I used a FWD block so i would have had to make my own anyways, V6 pads or not.
Old Sep 30, 2010 | 09:41 PM
Engine: 3.8, 3.4
Now see I kind of thought the K-members were the same, wasn't positive though. btw purple82ta, I noticed your car has K-member to subframe trianglular braces, did it come with those or did you buy them? And from what I can tell they bolt to the K-member, do they bolt to the subframe too, are are they welded to the subframes?
Old Oct 1, 2010 | 03:18 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
I think its better to ask them.
so actually its just the stock moun with some extra holes in it for the motor mountsfor the V6.
Old Oct 1, 2010 | 04:04 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
The K members are the same between V6 and V8 cars. There is 2 sets of engine mount bolt holes on them. The set closer to the front of the car is used for the V8 engines, and the set closer to the firewall is used for the V6 engines. When I did my V8 swap all I had to do was unbolt the V6 mounts and bolt in the V8 ones.
3rd gen RS - If you're referring to the braces I think you are, they are stock braces. The later 3rdgens came with them to help with front end flex I believe. They have 2 bolts holding them to the front of the K member, and 1 bolt attaching them to the underside of the frame rails.
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Blownz28man
Oct 9, 2008 10:28 PM
91 camaro racer
Sep 8, 2008 06:42 PM
90Formula-X-F
Mar 9, 2008 09:30 AM
KhaotikRaje
39
Feb 25, 2008 07:35 PM
