Squeaky shock
Old Aug 23, 2001 | 01:37 PM
One Eyed Jack's Avatar
Squeaky shock
My front drivers side shock likes to squeak a lot now. Is it going bad? The previous owner said they were new so they shouldnt be more than a year old. What should I do? its really an annoying squeak.
Old Aug 23, 2001 | 06:24 PM
82camaro's Avatar
Car: 82 camaro SC
Strut not shock. Probably not the strut making the noise, check the control arm bushings and grease everything really good.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
[This message has been edited by 82camaro (edited August 23, 2001).]
Old Aug 24, 2001 | 06:32 AM
LarsZ28's Avatar
I had this problem. It was the rear shock though. I couldnt figure out what was squeaking out the back. So after a bit of investigating (bushes etc..) I checked the top bolts for the shocks, and one was completely lose, causing it to squeak! Tightened it up, and no more squeak! Maybe check the bolts first, cant hurt..
Old Aug 24, 2001 | 07:14 AM
ede's Avatar
ede
if anything squeeks replace it don't grease it, that might make the noise go away for a while but the problem remains.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 24, 2001 | 07:44 AM
82camaro's Avatar
Car: 82 camaro SC
Grease it to find out what part is causing the problem. Of course replace it if needed.
82camaro
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
