How to swap in a quick ratio steering box???
Old Sep 8, 2001 | 12:22 PM
AntiVTEC's Avatar
Ok, I've got the box out of an 89 IROC, what will be involved with the swap? Are there certain things that have to lined up? What about the lines that run into the box? Any lock tight or urethane sealant required on them? I know this sounds silly, but do you have to bleed the power steering lines? Thanks! PAYCE.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si.
Old Sep 8, 2001 | 03:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's about as simple a thing as you can possibly do...
Disconnect the Pitman arm from the center link; remove the lines; remove the steering column from the worm shaft by way of the one bolt right next to the gearbox; undo the 3 bolts; installation is the reverse of removal. You might want to have new O-rings on hand for the lines, but that's about it.
ICON Motorsports
Old Sep 8, 2001 | 03:11 PM
AntiVTEC's Avatar
Is the pitman the one attached to the steering box? Or is that the ilder arm, because i've had the ilder arms replaced with MOOG parts and i wanna keep them. I know which one the centerlink is, the one that attaches between the idler arms. Correct me please!
Old Sep 8, 2001 | 07:43 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
Pittman arm: connects to steering box
Idler arm: on the opposite side of the centerlink
Old Sep 9, 2001 | 03:56 PM
Jza's Avatar
Jza
Yes, you have to bleed the lines. You do that by turning the wheel to each lock with the wheels off the ground (engine running at 1500rpm). Check fluid, and repeat until no more fluid needs to be added. Then lower the car and repeat a couple more times.
Before you start, make sure you have something to plug the lines with, (like some rubber or foam plugs) so you don't end up taking a PS fluid shower the whole time. You also might want a tie-rod end puller; makes life much easier.
Jorlain
Aug 24, 2022 05:11 PM
Dkelz313
Apr 7, 2016 10:38 PM
backtothe80s
Sep 5, 2015 12:39 AM
hectre13
Aug 26, 2015 08:17 AM
happyhapka
Aug 15, 2015 04:42 PM
