Question on rear swaybar size
Old Sep 10, 2001 | 12:55 PM
Steve's Avatar
Car: 91 Z28
I have a 91 Z28. I measered the rear swaybar with a cresent wrench and then measered the gap. I came up with 23mm. I thought it was supposed to be 24mm. I was wondering if that could actually be the size?
Thanks,
Steve
Old Sep 10, 2001 | 03:27 PM
82camaro's Avatar
Car: 82 camaro SC
I sure your 'cresent' method could be off a mm.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
