Suspension
Old Sep 23, 2001 | 11:38 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Suspension
Will KYB GR-2 shocks and struts make my iroc ride better than with the Monroe Sense-a-trac (sp?) that i have on now? Differences?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Sep 24, 2001 | 03:53 PM
82camaro's Avatar
Car: 82 camaro SC
It depends on what you mean by "ride better". If you mean softer, I don't think you will find a softer strut than the monroe's.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 24, 2001 | 04:24 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Guess i should have been more clear on what i want to expect. My monroes don't have very good weight transfer. I heard KYB has shocks that would help with my problem until i can actually get my suspension parts in.
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
