Rear Brakes?
Old Sep 19, 2001 | 07:45 PM
camaroN00B's Avatar
Rear Brakes?
I test drove an 88 Iroc w/305 the other day, and the owner said the rear brakes were "jumpy" because they were new. They were extremely jumpy. Depressing the pedal at any speed to slow down results in a "thump thump thump" that you can feel from the rear. Will this correct itself or am I looking at an expensive repair if I get into buying this car? Curious....
Ian
Old Sep 19, 2001 | 11:47 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
There is something wrong with them, either installed wrong or wrong parts.
Brakes aren't "jumpy" when new, only when there is a problem.
Have it looked at buy a mechanic before you buy it, if the guy won't let you take it to a shop for a looksy, hes hiding something. Shop elsewhere.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Sep 20, 2001 | 03:20 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Jumpy brakes because of new parts? This guy is full of it. Sounds like warped rotors to me from past experience,can be expensive.Have it checked out before you buy it.Good luck.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Sep 29, 2001 | 10:31 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Advice from Pink Floyd: Run Like Hell.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
