Tubular torque arms and binding
Old Sep 29, 2001 | 09:21 AM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
Transmission: turbo350
I've read the discussions on binding with boxed and tubular rear suspensions, interesting stuff. Nobody mentioned anything about a tubular torque arm. Will that mod alone cause binding and is it worth the expense if it doesn't?
New and Improved, ie Not so Cheesy
Sharons Virtual Junkyard
Old Sep 29, 2001 | 05:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, it will not cause anythign to bind as long as it retains the geometry of the original. Same overall length, provision for some front-to-rear motion (slight change in length due to suspension travel)at one end, same mounting to the rear end, etc.
ICON Motorsports
Old Sep 29, 2001 | 06:57 PM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
So the aftermarket arm that bolts to the floor plan instead of the tranny is no good, since it doesn't provide front/rear motion?
Old Sep 30, 2001 | 01:58 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
The aftermarket torque arm that "bolts to the floor pan" is fine. It DOES HAVE provisions for longitudinal (forward and rearward) travel of the torque arm. Basically they just add another cross member behind the trans cross member, and mount front end of the control arm to that in some manner that allows longitudinal movement, but NO vertical or lateral movement.
Old Oct 3, 2001 | 12:55 AM
superman46's Avatar
dose any one have a pik of their tork arm that they have put in a diff spot i want to do this but i wouls like to see some pik pleas
Old Oct 3, 2001 | 01:14 AM
superman46's Avatar
Dose any one have a pik of theirs i want to do it but i want to see how it is done frist
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
