Will my front suspension need to be redone to put in a big block?
Old Oct 24, 2001 | 10:54 PM
jharms's Avatar
I'm putting in an Olds. 455 in my '86 Firebird with a 305. Will my front springs and suspension need to be replaced to handle the new power and weight or will stock be fine? Also, where can I find sub frame connectors for my car so it will be able to handle the new torque that the 455 will crank out? Anything else I might need to cover? Thanks for your time!
Old Oct 24, 2001 | 11:17 PM
SoCo80p's Avatar
i would say the front end will be allright, the engine probley weights about 150 lbs more, so basically just sit on the front of your car and look how it sits, thats how it will with the new engine, probley only a inch or 2 lower, if its a big deal then all you need to do is swap out the springs, southside machine also make a great frame tie kit for the 3rd gens.
Old Oct 25, 2001 | 03:19 AM
Tas's Avatar
Tas
some strong new WS6 or IROC springs might be a good idea.
-Tas
'89 Formula WS.6
Old Oct 25, 2001 | 11:12 PM
jharms's Avatar
Where can I find "Southside Machine" on the web to get that sub frame connectors from them? Thanks for your input!
customblackbird
Aug 15, 2021 10:16 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
