Proportioning vlave...
Old Oct 26, 2001 | 08:29 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Any rebuild theirs?
Anything I should know before I do mine?
13.2 @ 102.6MPH 60 degrees w/ still no tuning on motor
Sportsman II, Gear drive, Perf. Res. chip, SLP 1 3/4" headers, Edelbrock muffler, Trans-go stage 3, Vigilante 9.5", Functional Ram Air hood, SLP roller cam, 24lb ADS injectors, AFPR, 3.45 gears, Stealth intake, 58mm setup, Spohn suspension, and other goodies...
raven
Custom EFI Intake Setup
Old Oct 26, 2001 | 11:08 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
As far as I know you can't rebuild a proportioning valve(factory..right?),just replace with a new or used one.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Oct 26, 2001 | 04:50 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Why are you replacing the proportioning valve?
