How hard is it to remove the front cross member?
Old Oct 29, 2001 | 08:55 PM
JucinGTA's Avatar
I want to do it, but this is the one thing I have never touched on a 3rd gen. Is it worth it too clean it up? Oh ya the car has no engine now anyways. How easy would it be, if I consider a engine swap a somewhat minor job?
Any help appreciated!!!
Old Oct 30, 2001 | 10:09 AM
JucinGTA's Avatar
ttt
Old Oct 30, 2001 | 02:40 PM
TVP123's Avatar
VERY easy with the motor and trans out .. drop the sway bar , disconnect the pitman arm from the center drag link , unbolt the top of the struts , disconnect the brakes lines at the rubber lines , and then you can
drop the 6 bolts holding the subframe in I have mine loose waiting for Ground Control to run the "weld in" weight jack kits !!!! they have orders for 3 so far .. probably waiting for 5 or something ... I've been waiting 3 months !!!!
Old Oct 30, 2001 | 02:43 PM
JucinGTA's Avatar
Will the springs shoot out?
Old Oct 30, 2001 | 06:15 PM
TVP's Avatar
TVP
oh yeah .. I'm running the 5.5 x 9.5 springs
so I forgot about you stockers :\ ... not to mention the usual disclaimers ... don't stare into the sun ...etc ...etc ..
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
3rdgenparts
Aug 8, 2015 07:09 PM
