SubFrameConnectors?
Old Oct 26, 2001 | 10:54 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
SubFrameConnectors?
Is there anything that needs to be done before Sub Frame Connectors are installed?
Which are better, bolt on or weld on?
1987 Z28 Black & Silver 305 LG4/5-Speed . . .
NRA/AMA/FOP/IUPA/Blue Knights
Old Oct 27, 2001 | 01:10 AM
SoCo80p's Avatar
the weld ins are the only way to go, the bolt ones really do nothing, also check to see what the companys says, sometimes you will have to relocate some of the suspention or bash up the floorboards.
Old Oct 27, 2001 | 07:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My Global West SFCs are weld-ins. The fit with a single cat (LG4) was perfect--no modification required.
JamesC
Old Oct 30, 2001 | 01:52 PM
cort351w's Avatar
Yeah, weld-in are the only way to go. The bolt in kind will never do as much, plus the bolt are subjected to almost continual stress, which causes the holes that the bolts go through to enlarge over time. Then your bolt-on SFCs are even less effective and you have large holes in your frame.
I would get SFCs that fit your car as is. Spohn, Global West (I think) fit. BMR does not make 3rd gen SFCs. Competition Engineering makes ones that required floorpan modification. Why mess with your floor pan though?
I was going to cut out my rear floor pan, invert it, and weld it back in to make room for mufflers down below to ease my dual exhaust setup. I took out the passenger side back seat and looked at it. The seat needs that hump. To simulate what it would be like with the floor pans inverted, I put the passenger side seat bottom on the driver side seat and tried to sit. I could manage, but I had to bend way forward because of that roof part of the car. I you raise your rear floor pans, I would suggest removing the back seat. But if you want to do that, those comp engineering SFCs are half the price of any others.
[This message has been edited by cort351w (edited October 30, 2001).]
Old Oct 30, 2001 | 02:42 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Having installed both, I am going to say get the Jegster bolt in subframe connectors. Drive the car around a few weeks, then weld them in. It is much easier. I put a set of the SPOHN Weld in connectors in an 89 Iroc ... what a pain. I have a set of competition engineering bolt in SFC's that I welded in a few weeks ago with great results.
Old Oct 30, 2001 | 08:22 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Buy the bolt on and then weld them. I know from experience
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
