Will 15 inch Rims clear 11.655 Rotors
Old Nov 5, 2001 | 10:56 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Will my 15 inch rims clear that big of rotors 11.655(this is stock size for the 89 9 bolt right). I found a totaled car and it has the 9 bolt BW rear end in it and I would like to put it in my car and keep my rims that are 15's. Will they clear these brakes? Rear is from a 89 TA also so most likely what gear set does it have?
1990 Camaro RS
1991 Acura Integra LS
check out my site: <A HREF="http://www.geocities.com/joecool_2u" TARGET=_blank>
</A>
LT1 motor stuff so far:
TPIS ZZ-9 cam, Comp Cams 1.6 Roller Rockers, Comp Cams "R" Lifters, Crane Cams Dual Valvespring kit, Underdrive pulley, and an air foil.
383 LT1 Stroker project has begun.
[This message has been edited by rickyzZ28 (edited November 05, 2001).]
Old Nov 6, 2001 | 10:33 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
You must be talking about the aluminum PBR rear calipers. My 15x7s clear them but not by much. It's not the rotor that's the issue, it's the ebrake linkage on the caliper.
Hotrodboba400
Dec 10, 2019 07:07 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
