Heavy Duty Struts??
Old Nov 24, 2010 | 11:54 PM
sickmade84's Avatar
Heavy Duty Struts??
I am about to put a 402 into a 1988 iroc z and was wondering if anybody knew of any good aftermarket heavy duty struts that would support the weight of a big block
Old Nov 25, 2010 | 12:08 AM
Stephen's Avatar
Car: 87 GTA
Re: Heavy Duty Struts??
The springs support the weight, not the struts.
The struts are just shocks that control bounce & rebound.
Old Nov 25, 2010 | 02:09 PM
sickmade84's Avatar
ok then what would be a good setup im sure somebody has done this i want the ride hight to look factory
Old Nov 25, 2010 | 06:54 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
2 options.
1) stock IROC or 91-92 Z28 springs are the stiffest stock springs. You could try those.
2) get a ground control weight jack setup with 800lb front springs, and adjust the ride height to suit you.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
MrPackstin
Oct 25, 2017 08:09 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
