interchangable parts
will coil springs from an 86 caprice work in my camaro. I know im beaing cheap but i already have the springs and it would be more convienient. also would the rear end from the caprice work, its posi and i only have a 1 legger. thanx
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The springs may fit but the spring rate will be all wrong.
The diff itself won't fit. It's the wrong width and there's no place to attach the torque arm. If it's a 7.5" 10 bolt (should be for an 86) then you could take the gears and posi carrier out and use it in yours.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
LT1Formula
20
Nov 14, 2015 12:02 AM
