Want to redo suspension, any pointers?
Old Nov 19, 2001 | 04:29 PM
duke_mushroom's Avatar
I'd like to set up my car for street duty, but I'll also be taking it to the drags and autocrossing when it's finished. I know I can swap all the bushings for polyurethane and get some SFC's. What else can I do, if it's still around, I'm thinking about taking it on the HOt Rod Power Tour someday. Thanks for any tips guys.
Old Nov 19, 2001 | 05:59 PM
SoCo80p's Avatar
the stock setup is more then fine just most everything, setting up a drag suspention is completely diffrent from a handleing suspention, if its just a cruzing car with a once in a while autocross race or drag then the stock stuff will be fine, even the poly will be fine, it usally wont become a facter in drag racing untill you start to get deep in the 13's
Old Nov 19, 2001 | 06:50 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Heres my setup and it hadles great. 1LE sway bars front and rear,energy suspension polyuretane bushing through the whole car, Spohn adjustable panhard bar,lower control arms, and subframe connectors,Koni red adjustable shocks and struts, Eibach pro kit springs and I rebuilt the whole front end with Moog parts. I would say start with a front end rebuild first because most of our cars have high miles on them and are in bad need of a rebuild. I would suggest only using Moog parts,stay away from the cheap stuff like TRW and such. New balljoints,tierod ends,idler arm and poly bushings will tighten the front end up and make it nice to drive.
Old Nov 20, 2001 | 11:07 AM
Thanks guys, I didn't know it would be that easy. I thought I might have to buy a whole new complete suspension all the way around.
Hmm, I always thought my car handled really well for stock suspension.
Thanks again.
Old Nov 20, 2001 | 01:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Aint' it funny how Moog and TRW are both made by the same company?
Think about replacing your idler arm and center link... they're common "wear" items on the 3rd gen f-body. Yours might be worn out, and you don't even realize it...
-Tom P (Hot rodded 1986 Firebird 2.8l)
LT1Formula
Oct 8, 2015 08:34 PM
shanelique22
Oct 3, 2015 07:23 PM
