only one subframe connector
Car: 1991 RS
Engine: 350tbi
Hey, I finally got my car on a lift today and found out I only have the left side sub frame connector! They were obviously homemade and the left side is all there but it looks like the right side was cut to make room for bigger exhaust. there appears to be some damage to the back right frame where it would have been. So my question is, will I be able to put a new one on with the damage? Also is it bad for me just to have one? Should I take it off?
thanks
thanks
Car: 87 GTA
Re: only one subframe connector
Take some pics & show us. Hard to say much, not knowing anything about these homemade SFCs or what was done to one for the exhaust clearance.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Different brands attach at different points.So you can always buy a set that avoids the damaged area.Or fix the damage & attach the new SFC same as before.Doubt leaving the loner connector would do much/any harm.
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
It wont due any damage ... i have been driving around for 6 years with only 1 because i cant find a shop that will custom make me one.. they keep bitching about my exhaust.. i keep telling them it has to be bottlenecked down to slide under.. they keep saying they have to rebend the whole system
Car: 87 GTA
http://www.umiperformance.com/catalo...kpk9asm26qtmc4
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
