Shocks
Old Nov 18, 2001 | 05:30 PM
88camaro's Avatar
Shocks
i just looked at my rear shocks and they r leaking ...
so i think i provably need t oreplace them,
but now the question which brand should i buy , and should i buy a stock replacement or something else ...and should i replace the front ones aswell?
need as much info as possible
thnx
AK
Old Nov 19, 2001 | 05:48 PM
88camaro's Avatar
can any1 help?
Old Nov 19, 2001 | 05:57 PM
SoCo80p's Avatar
if its just for cruzing any gas shock will be fine, gabrial or monroe or other name brand, i've used them and they work fine and are only like 15$ each at the parts store.
Old Nov 20, 2001 | 07:48 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by 88camaro:
thnx
AK
</font>
i use the monroe sens-a-trac. they work fine. you don't have to replace the fronts at the same time. but, if the rear are bad, the fronts aren't far behind.
Old Nov 21, 2001 | 04:25 PM
Shox.com's Avatar
Bilstein is one of the best and they aren't too expensive.
Old Nov 21, 2001 | 06:28 PM
camaro6spd's Avatar
my car is lowered and the guy before me did not adjust anything to complment this. I place on getting Spohns LCA relocate brakes, LCA and panhard bar....All adjustable(but what do I adjuct them too?) and was thinking to get KYB shocks and struts while I am at it....what do you think KYB is good right?
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways........Wrecked by a deer.
Looking for a 1995 Honda CR125R in NJ or PA. I have one for sale...RRP Sleeve Job, Vertex Piston, New Sprokets and a x-ring chain, new botom end with crank...etc etc
look here
http://www.classifieds2000.com/cgi-cls/ad.exe?P1+C18+R100004616
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Nov 26, 2001 | 11:58 AM
Shox.com's Avatar
KYB's are good.
Old Nov 26, 2001 | 12:55 PM
blue91rs's Avatar
KYBs are real good. Try to get the adjustables, not sure if they make them for thirdgens, but have seen them applied on other cars and they are the best suspension upgrade I've seen value wise.
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
