Body offset
Old Dec 17, 2010 | 12:22 PM
tricky1's Avatar
Car: 1982 Pontiac Trans Am
Engine: Chevy 350 Vortec Roller
Transmission: Turbo 350
Axle/Gears: Moser 4.11
Body offset
I put some taller wider tires under my 82 Trans Am and one side started biting into the sidewall just a little bit at the top 1/2 to 1" of the tire. I used a plumbob and found out that my rear end is offset one half inch to the side that's having the problem. Is there a way to correct where the body sits over the rearend?
Old Dec 17, 2010 | 01:08 PM
ChromePhoenix's Avatar
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
Re: Body offset
An adjustable panhard bar. it will allow you to recenter the rear and should take care of the rubbing problem.
Old Dec 17, 2010 | 01:14 PM
Stephen's Avatar
Car: 87 GTA
Re: Body offset
I discovered the same thing when I went to fit my 315s on. I used 1 long string with a washer on each end as my plumb bob, so that I could check both sides together while I adjusted mine.
Old Dec 17, 2010 | 01:28 PM
tricky1's Avatar
Re: Body offset
The rearends a Moser 12 bolt with a 4:11 gear and the wider tires are some Hoosier Quick Time Pro 28 x 11.5's. I was running the 27 x 10.5's but a new motor and crappy track prep by the dragstrip owners made me go back to the bigger tires. I'm looking at a Hotchkis adjustable panhard rod at Summit for $108 but Christmas has me by the short hair financially at the moment. Oh yeah, and my plumbob was a piece of nylon twine with a hex head nut tied on the end. Crude but effective.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Kenwood
Sep 4, 2015 05:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
