larger rotors, what do I need?
OK, whether or not you read my related post...
What do I need to upgrade to larger front rotors...other than the rotors of course.
bias valve right? what else?
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
Unless you havethe time and resources to properly engineer a brake SYSTEM, I would reccomend you use what works like Baer, SSBC, RoadTech, or Wilwood. Don't go jacking with things just to have bigger rotors. I'm if I were you, I'd jsut put on new rotors, quality pads, SS lines and fresh synthetic fluid. You'll be amazed at the difference.
I personnaly am using 6 piston calipers. ofcourse, I'm slowing from nearly 200mph
I agree, since you would need completely different mounting hardware for your calipers. Either a full 1LE setup, or going with a complete aftermarket kit.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 5151 150HP kit
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
dbrochard
Sep 19, 2015 08:13 PM
