STEERING COLUM
Old Jan 10, 2011 | 09:34 AM
92RSCAMAROGA's Avatar
STEERING COLUM
looking for info on replacing sterring column in 92 rs with one that has no air bag any info would be helpful
Old Jan 10, 2011 | 04:51 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: STEERING COLUM
Why not just change the steering wheel to a non-air bag wheel?
Changing the column isn't hard at all though, 7 bolts, 5 plugs, and one wire going to the gear selector if its automatic, not counting removing that under dash panel which has another couple bolts. Not sure if all the plugs will match up though if you use an older non airbag column, maybe someone else would know that.
Old Jan 10, 2011 | 07:36 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: STEERING COLUM
just remember to remove the battery positive cable for atleast 10 min before removing any wires for the air bags
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
