body flex
Old Apr 3, 2011 | 05:55 PM
joegugino's Avatar
Car: Iroc
Engine: 6.2l LS3
Transmission: 4L65E
Axle/Gears: 10 bolt 3.42
body flex
how much hp can a 86 camaro take with t tops w/0 flexing. and then with sub frame connectors? i was thinking of puting a ls3 of 620 hp in the car.
Old Apr 3, 2011 | 05:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: body flex
Welcome to TGO. Even an LG4 (a puny 305) will put stress cracks behind the drip rails of a coupe, though I suspect that would be eliminated with SFC's.
JamesC
Old Apr 3, 2011 | 07:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: body flex
Really has little to do with power like mentioned - it's simple driving. Entering a driveway at an angle so your air dam doesn't scrape flexes that car alot. Engine power has very little to do with it - until you get into stickies and clutch dumps, 1000 hp motor won't flx the car anymore than 150 hp.
Old Apr 3, 2011 | 08:39 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: body flex
put the subframes on anyway. GM didnt stick the 350tpi behind a Ttop car for a reason. I had cracks in the corners of my doors in my stock formula 350.
Old Apr 4, 2011 | 11:42 AM
Pocket's Avatar
Car: 91 Trans Am
Re: body flex
Hardtops all cracked along the upper corners. Its just body flex, V6's got it just as bad
Also, 350 and T-tops were available, just not all years
SFC's are a good idea for any 3rd gen, V6, stock, super mods, whatever
Old Apr 4, 2011 | 11:46 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: body flex
I'd say that car would want quality subframes and a 6 point roll bar, with 620hp you're well into the 10 second range at the track and it would be a safety requirement regardless.
Old Apr 4, 2011 | 03:03 PM
Car: 87 TA clone
Re: body flex
Didnt GM beef up the later years chassis inorder to accomodate the 350?
Old Apr 4, 2011 | 03:05 PM
Car: 87 TA clone
Re: body flex
agreed, first time u hit the 11.99 sec barrier there not gona let you do anymore runs. A 6pt is required at 11.99s and 6pt means door bars, hoop and rear bars... trans tunnel bars are not included in a 6pt. And putting 6pt bars (hoop, trans tunnel and rear bars) is not legally a 6pt roll bar.
Old Apr 4, 2011 | 03:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: body flex
No.
I'm going to move this to chassis and suspension, since this isn't an engine swap topic.
Old Apr 4, 2011 | 05:17 PM
Pocket's Avatar
Car: 91 Trans Am
Re: body flex
No, T-top cars got the little snubbers in the door jambs but thats it. 92 cars got some extra adhesive to quiet rattles, but no chassis changes
Old Apr 4, 2011 | 05:27 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Re: body flex
11.49 or faster and 13.49 for convertibles.
Hotrodboba400
Dec 10, 2019 07:07 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
New2Chevy
Sep 28, 2015 12:35 AM
Kenwood
Sep 4, 2015 05:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
