Rear end seems loose
Old Apr 10, 2011 | 04:54 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
i was out working on the 86 iroc the other day, i noticed when you shake the rear of the car, it seems to sway and have a little play, i know of some cars that do that but not as bad..is it fairly normal for ours? it's rear drum, independent 10bolt back there.. not the best i know
Old Apr 10, 2011 | 05:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rear end seems loose
is the panhard bar missing or broken, or have blow out bushings? thats what holes the axle in the car side to side, and without it in good working order, the back of the car will be squirmy and the axle will move side ot side
Old Apr 10, 2011 | 06:12 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
rear controll arms bushings shot
Old Apr 11, 2011 | 02:46 PM
1988-305-tbi's Avatar
the panhard bushings are shot or the vehicle has been lowered or raised too much and rear geometry of panhard is out of whack... allowing side to side movement
Old Apr 11, 2011 | 02:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There's not much actually holds the rear axle to the car. There's torque arm (which wiggles in the tranny mount), panhard bar, rear shocks, sway bar end links, and the lower control arms. LCA's are flexible if factory, not very strong and thus alot of folks box them or buy solid mounts. End links are designed to move, shocks don't have a very good top mount, panhard bar only centers left to right. It's kinda the nature of the beast (until you replace those things with tougher less flexing parts.
Old Apr 11, 2011 | 03:03 PM
jeff_blake's Avatar
alright. yeah its not to horrible, im just trying to get it street ready now. minor odds and ends here and there.
Old Aug 11, 2012 | 01:22 AM
jeff_blake's Avatar
year later! yeah its the panhard, its been torn apart all year, back togethers and panhard is the last thing! thank all
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
