diameter of sway bar.
Old Apr 16, 2011 | 05:01 PM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
hello..i have a stock 1991 camaro rs with a 305ci v8 and automatic. i need to replace my sway bar links, sway bar bushings, and sway bar end links. what is the diameter of my sway bar..i havent got to get it in the air to check.
thanks
Old Apr 16, 2011 | 05:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: diameter of sway bar.
If just replacing the endlinks the size of the sway bar doesn't matter.
Old Apr 16, 2011 | 05:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
but he wants to replace the bushings too, so it does matter.
OP, you have to measure it. you can do it from the top. only way to know for sure.
Old Apr 16, 2011 | 05:14 PM
Car: 1992 RS
Engine: Carbed 350
- old eyes missed the bushing part - just saw the links part.
Yes, you'll have to measure - no telling what GM used on YOUR car.
Measure right where the bushing goes, clean gunk/grime off to smooth metal, and use a caliper - you need a measurement in millimeters.
Old Apr 16, 2011 | 09:10 PM
thanks guys..i was told it was 32mm. but i saw where iw as going to order from they didnt have 32mm. so i wanna make sure.
camaro1185
Oct 26, 2015 06:51 AM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
87camaro87
Sep 9, 2015 10:29 PM
