Energy A Arm Bushings
Old Apr 26, 2011 | 06:46 AM
iroc_valencia's Avatar
I've purchased Front A-Arm bushings from Energy for my 1986 IROC-z , the energy p/n is 3-3157G , i've noticed a lot of freeplay between the inner sleves (small tube contacting bolt) and the bolt , you can flip it up and down , and they had the same Inside Diameter than the stock ones (1/2") , is normal that free-play ? anyone have dealt with this before ?
Old Apr 26, 2011 | 08:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Energy A Arm Bushings
the ES bushings have a 1/2" bore, and the stock bolts are 12mm, so there is slop. I drilled the holes in my k-member to 1/2" years ago just because of this issue, and it makes finding bolts easier.
once they are tight, they should settle in the mounts and i dont think you will have any issues.
Old Apr 26, 2011 | 08:47 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I didn't notice that when I installed mine, but I had such a hard time getting my A-arms back in that I wasn't paying much attention. I was happy just to have them back in. I've put over 5k miles on the Camaro since I installed them and haven't noticed anything but an improvement over the stock rubber pieces.
Old Apr 27, 2011 | 04:12 AM
Yes , i've figured that , there's a little slop , but the stock sleeves measured the same (1/2 ") , and i assume this is normal , but initially looked really scary for me.
I was wondering the same , once they're tight , will settle.
Many thanks bud.
Old Apr 27, 2011 | 05:15 AM
Nice , this is what i call , quality control , hahahah , i know , this probably won't give me a "notable performance upgrade" but the old ones were completely shot , and energy product seem's to be a good replacement.
Thanks for the reply!
Ed1LE
Sep 30, 2018 09:14 AM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
