Rear Suspension Issue
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Just replace the front and rear springs and struts. the other day i was looking at the car and the rear drivers side is sitting almost a fist lower than the passengers side
Anyone have any suggestions?
.Anyone have any suggestions?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Suspension Issue
JamesC
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Ill double check. the driver side sits a fist between the lipand the tire. and the passanger side sits almost double that. my dad said it might be the rubber being worn that go on top off the spings.
but ill try to put the rear out today and see what every thing looks like.
JamesC
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
That’s were I’m confused. I have a big shortage of space compared to the other side. When I take things apart later maybe it will explain it’s self.
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
last night i was able to get under the car. The springs seemed to be seated correctly. i did however find that the PO is a terrible welder. both brackets that weld to the chasse for the sway bar popped off. the welding looked like he was welding with a mig and had the wire hanging a foot out. it was just spatter every were. so i rewelded the brackets the right way and reattached the sway bar. Rides a lot better now, that f***in noise is gone. but i wasn’t able to check how the car sits. ill check when i go on lunch today.
LT1Formula
Nov 16, 2015 01:13 PM
