front suspension
Old Jun 9, 2011 | 06:09 AM
dv718bx's Avatar
front suspension
I recently had the front driver side ball joint replaced the mechanic said all else is good until I drove it home and still every time I turn the wheel hit the gas /brake the front end has a clicking sound and its annoying to drive the car, anyone have any insight?.
Old Jun 9, 2011 | 08:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: front suspension
Nature of the beast. A wonderbar helps, but even after redoing my entire front suspension, I still get creaking on slow tight turns (like parking lots). I just choose not to turn like that anymore, and I've learned to park accordingly.
Old Jun 9, 2011 | 10:16 PM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Clicking or clunking anyways i would check your swaybar bushings and links
Stock tires?? Check for any rubbing could be a wheel bearing going also
Old Jun 9, 2011 | 11:08 PM
wretched737's Avatar
Check all bushings
Old Jun 11, 2011 | 10:17 AM
karl's-92'-z28's Avatar
Car: Too many cars
Shake the frontend down to see if anything is loose, also check brake pads for movement in the caliper & also check A-arm bushings for wear.
Old Jun 12, 2011 | 10:46 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
if it didn't do it before he changed the balljoint, take it back to the shop that did the balljoint and talk to that "mechanic" cause he obviously didn't put it back together right.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
cam-mike
Aug 24, 2015 07:23 AM
