help
Old Jun 26, 2011 | 08:04 PM
jll87TA's Avatar
Car: 87 trans am, 82 trans am
Axle/Gears: stock
help
Ok so i have an 87 trans am. I notice that from the passanger side is lifted more than the driver side its probaly an inch or 2. Does anybody know what this might be?
Old Jun 27, 2011 | 09:30 PM
jll87TA's Avatar
Axle/Gears: stock
Re: help
Bump
Old Jun 27, 2011 | 11:02 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: help
broken spring possibly. something loose. have you looked to see if you noticed anythign different?
Old Jun 27, 2011 | 11:51 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: help
broken spring or missing isolator perhaps, chances are its at just one of the wheels.
Old Jun 28, 2011 | 12:01 AM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
Re: help
How can you tell? is there a bigger distance from the top of the tires to the wheel well? My first thought is Coil Springs. When I first bought my car, someone had removed and cut the factory springs. The one on the driver side was one "coil" (or twist) lower than the passenger side. I dont know how someone could make that mistake but it happened.
Old Jun 28, 2011 | 03:05 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: help
If it's original, than it's normal. My car was 1.5" lower on the driver sides than the passenger side (with original springs). Chalk it up to me driving the car by myself 99% of the time. That's an extra 200+ lbs on the driver's side that doesn't exist on the passenger side.
New springs = balanced sides.
