Got everything aligned. Good specs?
Old Jul 7, 2011 | 02:12 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The tire place said they got .5 camber on both sides. .01 Toe on the right side and .02 on left side. 4.9 Caster on right side. and 5.1 on left side.
Old Jul 7, 2011 | 02:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Got everything aligned. Good specs?
if thats negative camber and toe in, it seems fine.
Old Jul 7, 2011 | 02:26 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yup. Both negative. To get the .5 Camber , my UMI strut mounts are maxed out, Both sides. For caster its maxed out as well on the plate but the top adjustment for the strut with the umi plates have tons of room. I can still move the strut back 3/4 of an inch.
Old Jul 7, 2011 | 03:17 PM
Looks OK to me...
Expect the inside edge of the left tire to rub at the bottom outer rear of the fender in hard right turns, and the right tire to do the same on left turns, from having the spindle set so far rearward. Just comes with the territory I guess.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
Electro_X
Aug 19, 2015 07:59 AM
