loud bang from rear passenger tire area
Old Jul 13, 2011 | 02:36 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Engine: stock 2.8L V6
Transmission: stock
Axle/Gears: stock
Ok so i thought at first it was the spare tire in the back making the bang when i take off hard from a stop, so i took that out and it still happens.
anybody have this bang before or can tell me how to go about diagnosing the bang
Old Jul 13, 2011 | 03:11 PM
Re: loud bang from rear passenger tire area
Check your trans mount.
Old Jul 13, 2011 | 04:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The trans mount is usually characterized by feeling a "bang" through your shifter tunnel. If you're pretty sure it's in the back right area, check the springs, shocks, LCA's and anything else in that area. It should be pretty apparent what's "not right" in that area.
Old Jul 13, 2011 | 04:34 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Im having a similar bang when i go over a big bump or in a pot hole. Happens to be the back panel that covers the rear hatch motor that's jumping up and down. Might not be the case for you though.
Old Jul 13, 2011 | 05:30 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
ok thanks guys, next day when the heat is not unbearable i get under there and start looking
Old Jul 13, 2011 | 05:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
could be a trashed panhard bar bushing, or loose bolt.
a bad shock will do that too.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
mustangman65_79
Apr 14, 2017 05:37 PM
db057
Aug 22, 2015 08:17 PM
