Subframe connectors
Car: 86 Camaro
Engine: 5.7 with some mods.
Transmission: 700r4 needs shift kit
Axle/Gears: Stock.
Subframe connectors
http://www.jegs.com/i/Jegster/550/40053/10002/-1
I recently bought these w/o instructions and can't figure them out. Could some one help me out please? I don't know what side is what or where to bolt to. Thanx
I recently bought these w/o instructions and can't figure them out. Could some one help me out please? I don't know what side is what or where to bolt to. Thanx Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Subframe connectors
the end with the single hole sandwiches on with the rear LCA bolt, on the outside of the mount. The front looks like it bolts to the floor by the firewall, you will have to drillholes.
It would be best to have those welded in.
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
"Installation can be completed with hand tools" is a VERY vague statement. Thats where they get ya. Thread Starter
Car: 86 Camaro
Axle/Gears: Stock.
Thanks, I will take a look but for some reason they didn't seem long enough for that. I don't know I'll try again maybe I missed something.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The flat one is for the Drivers side, the stepped one is for the Passenger side.
You can call/email Jegs & ask for Install Instructions to be mailed/emailed to you.
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
When you install SFCs, the car should be resting on it's wheels, correct? Not on a 4 point lift?
Car: '89 GTA
Engine: 5.7L LS1
A 2 post lift has the arms that swing out and it can be done on those but requires a bit more work to do so 'correctly'.
A 4 post lift(drive on) is usually the best choice.
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
