Founders Bolt-in LCARBS + PBR 9-bolt
Old Aug 20, 2011 | 11:45 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Wasn't going to install these in my car just yet but I went and held them in place where they would go it looks like the pbr emergency brake cable brackets are going to interfere. Not sure quite yet how much I'm going to have to trim but its definitely gonna need to be done.
I seems like I can just trim enough off to clear and not go all the way to the cable housing but only installation will tell.
Old Aug 20, 2011 | 11:59 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Founders Bolt-in LCARBS + PBR 9-bolt
bend the brackets or remove them if your state doesn't require them for inspections?
Old Aug 21, 2011 | 02:08 AM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Ok I lied, I went ahead and installed them. Took a whiz wheel to them and worked out well, just enough room to spare. No real harm done and I'm astonished at how easily they installed!
Once I got the bracket bolted up I took my BMR fixed poly/poly control arm, raised it up and the holes were 100% perfectly aligned on both sides.
For founders, I'm definitely a repeat customer.
IMG_20110821_003406.jpg?t=1313909941
I could have trimmed this one a little more but it'll do.
IMG_20110821_012632.jpg?t=1313910028
Old Aug 21, 2011 | 10:20 AM
That's EXACTLY what I had to do when I put LCARBs on my car. I think mine were Spohn, but it hardly matters; by definition, the LCARB has to be just exactly there, there really isn't much choice; but the brake bracket happens to intrude into that volume. Not much else you can do about it.
Didn't seem to really bother the function of anything.
Old Feb 1, 2012 | 10:10 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
mine does this too and that ear is really close to the wheel..but from what i was looking at..the ear bolts to the shock mount on the side closer to the motor right? or did you guys cut em off??
Old Feb 1, 2012 | 11:37 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
If your talking about the ear I think your talking about, it goes right on the front side of the shock mount and the shock bolt goes through it. If it wasn't there then there wouldn't be any way to keep the bracket from rotating.
Old Feb 1, 2012 | 11:44 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
oh ok cool took it all apart the other day and couldnt get it but i thought it went on the inside for some dumb reason -___- lol
J-money
Jan 4, 2019 09:45 AM
///DAN///
Sep 25, 2015 02:15 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
6speedIROC
Sep 13, 2015 01:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
