Clunking Back End
Old Oct 18, 2011 | 12:24 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
Clunking Back End
my 91 RS occasionally clunks when I take a corner or hit a bump. I also noticed that when my car is sitting still on a flat surface I can push on the quarter panel and the body of the car can move back and forth but the rear axle stays in the same place. What would do this? I there a panhard bar bushing or something thats gone bad?
Old Oct 18, 2011 | 12:30 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Re: Clunking Back End
exactly! the first thing i would check is the bushing, bolt on the panhard bar! i experienced the same issue after i had the ring and pinion swaped. they never tightened it. i figured it was play in the axle, turns out it was a free simple fix just tightened it up and good as new. car felt like it was floating while driving over dips and bumps.
Old Oct 20, 2011 | 11:04 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Yeah, check the panhard bar, bushings and mount brackets.
Old Oct 21, 2011 | 07:46 AM
UMI Sales's Avatar
Hey 91camarolover. Agree, it sounds like a potential bad bushing or loose bolts.
The stock Panhard on these cars is a weak link even when everything is tight. An aftermarket Panhard is one of the first and best upgrades you can do.
Give us a call if you need tech help.
Have a good weekend.
ramey
Old Oct 31, 2011 | 11:08 AM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Sway bar end links
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
