4th gen front suspension swap. (Is it possible)?
Old Oct 29, 2011 | 05:10 PM
91camarolt1's Avatar
Car: 1991 chevy camaro rs
Engine: 5.7 cid Lt1
Axle/Gears: stock
Just wanting to now if you can swap out the the cross member, lower contral arms, struts, spindles, and upper contral arms from a fourth gen to a third gen.
Old Oct 29, 2011 | 06:19 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 4th gen front suspension swap. (Is it possible)?
I assume you mean 98+?
If you have enough money or fab skills, yeah. But to do it you pretty much have to get the majority of the underhood sheetmetal. It is in NO WAY a bolt-on swap nor one that only requires "some" sheetmetal work. It is a BIG job. I only know of 1 car that has actually done it & that was in a show car, so no idea if it was really strong enough for a street car. & he swapped the whole firewall & almost the entire underhood between the radiator wall & the firewall, top to bottom.
Old Oct 30, 2011 | 09:21 PM
Engine: 5.7 cid Lt1
Axle/Gears: stock
Thanks for the info. I'm very happy i asked before I startewd. Thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
