Good V6 Daily driver alignment specs?
Old Nov 7, 2011 | 09:50 AM
DirtDawg57's Avatar
I have an 86 V6 Camaro not lowered and wanted to see what a good daily driver alignment specs would be. I don't really like the stock setup with all the positive camber. I just need something that will wear and handle good but not something super aggresive. Also I drive it through the winter with snow tires. Does anyone have a print off or some numbers I can give to the shop? Thanks!
Old Nov 7, 2011 | 12:07 PM
TTA579's Avatar
Car: Turbo Trans Am #579
Engine: 231ci (3.8L) LC2 (Buick Turbo)
Transmission: 200r4
Axle/Gears: Borg-Warner 9-bolt
Re: Good V6 Daily driver alignment specs?
What is "all the positive camber" you're talking about? Stock should be 0 camber or close to it. Stock is going to be your best bet.
Old Nov 7, 2011 | 01:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This is what I use:
Camber -0.25* to -0.30*
Caster: 5.0* (0* cross)
Toe-in, a hint (about 1/32")
Works well and prevents the inside edge of the tires from wearing.
The service settings from the '92 FSM are interesting:
Per Wheel...
Camber: 0.30* +- 0.50*, cross: 0.00* +-0.70*
Caster: 4.80* +- 0.50*, cross: 0.00* +-0.70*
Toe: 0.00* +- 0.10*, cross: 0.00* +-0.20*
This allows camber from 0.80* to -0.20*.
RBob.
Last edited by RBob; Nov 7, 2011 at 02:44 PM. Reason: removed extraneous decimal point
Old Nov 7, 2011 | 02:12 PM
DirtDawg57's Avatar
Ok thanks for the help! From what I read these came stock with positive camber to reduce oversteer for poor drivers, and many post say that it causes the tires to wear incorrectly. I had never heard of using + camber anywhere until this. I was thinking 0 camber would be good but wanted to check.
Old Nov 7, 2011 | 05:56 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I would go for a -0.3 camber in your situation.
Old Nov 8, 2011 | 10:52 AM
DirtDawg57's Avatar
Thanks! Thats what I was looking for!
Fanatic1074
Oct 3, 2022 05:57 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
my86bird
Oct 23, 2015 12:20 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
