NEED SUPPORT
Old Nov 17, 2011 | 04:31 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
NEED SUPPORT
The support is for the car, not me. I will be replacing my shocks, struts, and strut bearings in the next few weeks and would like to know if this can be done effectively with just jack stands. Also would it be better to place the stands under the car's jacking locations or a portion of the suspension like the spring seats(front) and axel (rear)?
I plan to drop in Koni Reds and J&M Bearings and, yes, I will have the car aligned after the installation is done. Thanks for any advice offered>
Old Nov 17, 2011 | 04:40 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: NEED SUPPORT
it can absolutely be done on just stands , put the stands on the sub frame ( if you look in you owners book it will show it ) just make sure you get it high enough so you can swing the a arms low enough to get the spring out ( be careful use a chain or strap them to the a arm so they don't fly) . Some guys like to get the whole car off the ground but that's up to you .
Old Nov 17, 2011 | 05:11 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Re: NEED SUPPORT
Thanks, Dan but I don't have coil overs, so why do I need to remove the springs? I was actually thinking of putting the jack stands under the spring seats to keep them compressed. Is this a good or bad idea?
Old Nov 17, 2011 | 06:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: NEED SUPPORT
putting the jack stands under the a-arms, as far outboard as you can, will be fine to support things while you change the struts. And you do not have ot remove the springs, i think that was just a mistake by DAN, must have thought you were installing springs at the same time
Old Nov 18, 2011 | 11:12 AM
///DAN///'s Avatar
Engine: 355 SBC
Re: NEED SUPPORT
my fault I thought you said springs too , right by the ball joint is where i put them .sorry for the mistake .
Old Nov 18, 2011 | 08:13 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Re: NEED SUPPORT
Thanks for the help, guys. I ordered the parts today and expect to do the install after the holiday.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Briandrex
Oct 5, 2015 06:20 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
