proven suspension?
Old Jan 30, 2012 | 09:20 PM
92blazenchicken's Avatar
Car: 1985 pontiac trans am/ orignal ws6
Engine: 5.0l 305 tpi
Axle/Gears: borg-warner 9 bolt 3.27
proven suspension?
i have a 98 trans am and with my tax returns this year im going to do some upgrades to my car. mainly doing full suspension. torque arm. sub. connectors. lca's and lca brackets. im just curious if anyone has proven time slips from the track to see what the actual tenths you pick up from suspension
Old Jan 30, 2012 | 09:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: proven suspension?
You probably won't gain anything. Suspension upgrades usually just helps consistency by removing flimsy and sloppy factory components.
Old Jan 31, 2012 | 01:18 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
I have the alston SFC's trom TDS there good but I am going to add the Spohn outside conectors as well to make my car more solid.
Old Jan 31, 2012 | 01:27 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Actually upgrading suspension will allow it to hook better improving 60 ft time. With adj torque arms you can angle the pinion of the rear end allowing you to adust "bite" of the ground and really get a good launch. Also upgrading things like a-arms k members there going shave weight off. Heres a link to a streetlegal tv post that can give you more information on it
http://www.streetlegaltv.com/news/al...ormance-parts/
Old Jan 31, 2012 | 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by 92blazenchicken
i have a 98 trans am....
Typo? If so, you might edit. If not, another site, such as the one linked to below, might be better suited to your needs:
http://www.camaroz28.com/
JamesC
Old Jan 31, 2012 | 07:21 AM
yeah im trying to get ride of my cars spinning through first and second. my buddy has a 00 ss 6 speed and with the torque arm alone helped his 60ft. i have the 98 auto and if i dont feather the throttle on a launch it just roasts the tires.
Old Jan 31, 2012 | 07:27 AM
JamesC's Avatar
Since your inquiry is non-thirdgen related....
JamesC
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
