drag race rear suspension
Old Feb 6, 2012 | 03:07 AM
88cvs's Avatar
Car: 1988 camaro
Engine: 383
Transmission: turbo 400
Axle/Gears: 9 inch 390,s
I have an 88 camaro sbc turbo 400/brake and a 3000 conv bmr adj tourqe arm, moser 9 in 4:30 gears adj lower control arms strange single adj shocks and 275/60/15 mickey thompson drag radials. The problem I have is this car wont hook at the starting line or else it wheel hops badly I have tried different pinion angles and shock settings as well as tire pressure nothing helps this is just a basic 435hp edelbrock mtr any help?
Old Feb 6, 2012 | 04:19 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: drag race rear suspension
do you have relocation brackets for LCA ?
best regards
Old Feb 6, 2012 | 08:05 AM
88cvs's Avatar
Car: 1988 camaro
Engine: 383
best regards
not yet do they help ?
88cvs's Avatar
Car: 1988 camaro
Engine: 383
do they help and whats a good one to get ?
Old Feb 6, 2012 | 09:41 AM
UMI Sales's Avatar
Hi 88cvs.
If you have a torque arm and LCA's already, relocation brackets are the next part of the puzzle.
Here's ours: http://www.umiperformance.com/catalo...dex&cPath=6_85
How much pinion angle are you putting in it?
ramey
Old Feb 6, 2012 | 10:21 AM
88cvs's Avatar
Car: 1988 camaro
Engine: 383
I have -5 degrees now but have tried several different angles this car runs from a best of 1.69 to 1.84 6o foots but wont run back to back and will just spin big time out of the blue or wheel hop badly
Vintageracer
Jan 10, 2020 05:33 PM
bjpotter
Jan 22, 2019 12:27 PM
cam-mike
Aug 24, 2015 07:23 AM
