Pitman arm removal.....suggestions
Old Feb 20, 2012 | 11:56 AM
erik69&85's Avatar
removing the steering gear for a rebuild... Got everything disconnected, got the big nut off with an impact gun and a 1 5/16" socket. But the pitman arm won't budge. Hooked up a 2 arm puller and drive it with my impact gun but still cannot get it to move. Looking for suggestions. Plenty of guys seem to be unable to get it off!
Considering adding a little heat, not a lot. Not glowing hot, just a little to open up the hole and free the rust. Hoping this isn't a problem for the cast iron part.
Use a pickle fork between the arm and the body?
Looking for ideas that work!
thanks
Old Feb 20, 2012 | 11:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Pitman arm removal.....suggestions
Liberal application of brute force and ignorance will get it off. If you break it, you needed a new one anyway.
Old Feb 20, 2012 | 12:26 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Some heat and a puller worked on mine.
Old Feb 20, 2012 | 12:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Don't be scared to use a buttload of heat and a puller..
Old Feb 20, 2012 | 01:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've never had to use heat to remove a pitman arm but a proper pitman arm puller helps. I've never used he 2 jaw puller.
These are the most common pullers
This is the style that I use
Old Feb 20, 2012 | 01:52 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
you can use this in every day life
just ask the Ford Guys!
on a side note:
any body make a slick aftermarket pitmen arm. from billet? sorta like the Nascar parts.
seen a few. that look like they would fit. but not the press/slide on style.
Old Feb 20, 2012 | 03:55 PM
erik69&85's Avatar
I'd freaking cut the thing off if I knew I could get another one but i have not seen one anywhere! Not even on Ebay. So I plan to do what i can to preserve the one I have.....
Just who the heck was Pitman anyway? And why was he so special.... must have been one stubborn guy.....
Old Feb 20, 2012 | 04:32 PM
3rdgenmaro's Avatar
Car: 88 IROC
Go rent the puller from autozone (free if you return it), put some heat to it, grab a breaker bar and a piece of pipe, man up and get it off.
Old Feb 20, 2012 | 04:40 PM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
heat, puller and big bar works everytime. i have had to due this many times when i worked in a shop
Old Feb 20, 2012 | 07:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
You can try tightening the puller as much as you can, then smack.the side of.the arm with a large hammer a few times. Might be enough to break it loose.
Old Feb 20, 2012 | 08:25 PM
cliff1970's Avatar
Car: iroc z
youve got to rare back and knock the **** out of it. it will fall off
Old Feb 21, 2012 | 09:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Good suggestions here, they can be very stubborn. Last one I did I was fed-up working on it and just left the puller on it tightened up. Next morning the pitman arm was off. Came loose overnight sometime.
RBob.
Old Feb 21, 2012 | 08:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I've never heard of removing one that way but I'm glad it worked.
Old Feb 22, 2012 | 07:13 AM
erik69&85's Avatar
SUCCESS!!!... For I have vanquished the arm of Pitman!
Here's how:
1. Used a forged 2 arm Craftsman puller. And got a good grip on the underside.
2. Soaked the connection with liquid wrench.
3. Tightened up the puller with a 15 inch driver.Very tight but not ridiculous.
4. Used a propane torch to put heat on the end of the arm.
5. After the smoke cleared, started smacking the connection end of the arm while still applying heat.
6. After a couple minutes, it popped off like a jack-in-the-box.
I can see how it might pop off overnight...the press fit on the tapered splines just gives all at once.....
Attached Thumbnails Pitman arm removal.....suggestions-img_20120221_190813.jpg
Old Feb 22, 2012 | 09:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Next time try a real pitman arm puller.
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
